[Gdal-dev] ECW File open failed
Ken Sewell sewell at dramail.com
Tue Feb 7 10:06:05 EST 2006
Yes, "gdalinfo --formats" does list "ECW (rw)"
I went ahead and downloaded the 3.3 RC1 and tried it on my 32-bit and my
64-bit.  gdalinfo on both machines show ECW in the formats list.  ECW on
the 32-bit seems to work, same error on the 64-bit.  The examples
included with ecwsdk3.3rc1 do run on the 64-bit system.  I'm trying to
dig further.  Is there an easy way to build a debug version of gdal?  I
haven't found a config option or a makefile target to do this yet.
Ken
On Mon, 6 Feb 2006, Frank Warmerdam wrote:
> On 2/6/06, Ken Sewell <sewell at dramail.com> wrote:
> > I'm running off of the GDAL CVS (16 Jan) with the ecwsdk-3.2.11Jun2005
> > package.  Gdal showed ecw support in the configure step. Both built and
> > installed.  When I run gdalinfo on an ecw file I get the following:
> > I'm running on SuSE 10.0/64-bit.  Can anyone shed some light on this for me?  Thanks.
> Ken,
> You might want to verify that "gdalinfo --formats" lists
> ECW format.  Also, I believe there is a 3.3 release
> candidate available that would be better than the 3.2
> version.  Lastly, I have not tried ECW on a 64bit machine
> yet.  That might be a step too far in this case. :-)
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
