[Gdal-dev] LinearRing and GetGeometryType
Didrik Pinte dpinte at itae.be
Wed Feb 8 05:51:44 EST 2006
I'm using the Python interface to OGR, but the problem will be
encountered in all the languages
As a subclass of OGRLineString, when calling geometry.GetGeometryType()
on a OGRLinearRing object, it returns ogr.wkbLineString type and not an
ogr.wkbLinearRing type.
It this behaviour normal ? or should it be modified ?
What should be the best fix for this problem ?
[1] implement GetGeometryType in OGRLinearString ?
[2] if the current behaviour is the right way to do it, just fix it in
my ogr.py file redefining the GetGeometryType for the LinearRing
objects ?
Didrik
Name: not available
Desc: Ceci est une partie de message
	=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060208/b6f26e6d/attachment.bin
