[Gdal-dev] Can't open a sid image under Russian locale
Peng Gao pgao at esri.com
Thu Feb 9 18:25:17 EST 2006
GDAL can’t open a sid with a Russian path name. The problem seems to be the name conversion in
LTFileSpec. The following is the name before and after.
I am using DSDK 5.0.6
/*      Create a corresponding GDALDataset.                             */
    MrSIDDataset        *poDS;
    const LTFileSpec    oFileSpec( poOpenInfo->pszFilename );
Before poOpenInfo->pszFilename:
“\\collingwood\checklist_data\Raster\I18N\Russian\фывdvim3_2.sid <file:///\\collingwood\checklist_data\Raster\I18N\Russian\фывdvim3_2.sid> ”
After oFileSpec.path8:
 "\\collingwood\checklist_data\Raster\I18N\Russian\Р‡в€љС‚dvim3_2.sid"
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060209/55ea57b0/attachment.html
