[Gdal-dev] ogr_miattrind.cpp dependency
Mateusz Łoskot mateusz at loskot.net
Fri Feb 10 06:48:18 EST 2006
Frank Warmerdam wrote:
> On 2/7/06, Mateusz Łoskot <mateusz at loskot.net> wrote:
>>>I think the best solution to this would be to add some sort
>>>of build/preprocessor magic so that if the mapinfo driver isn't
>>>included in a build, the attribute indexing will also be dropped.
>>>This may be a bit messy.
>>Do you think it's something recommended or expected by other users?
>>Or there is no problem with current state of this configuration?
> This is an issue for very few users (developers).  I'm not keen
> on doing anything about this, but if there is enough interest
> (or better yet helpers) something could be done.
Frank,
OK, I'll leave it as is for now.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
