[Gdal-dev] Can't open a sid image under Russian locale
Fri Feb 10 23:43:47 EST 2006
Peng Gao wrote:
> The path name passed into GDALOpen() is a multibyte string converted from
> a Unicode string using Windows call wcstombs().
Sean,
This is the case in Gao's application at least.  In general, it should
be in a form suitable to pass to the fopen() call on the system in
question.  I believe similarly encoded filenames have worked fine with
fopen().
Best regards,
