[Gdal-dev] Re: NOAA 14 GCP reading error
Markus Neteler neteler at itc.it
Thu Feb 16 08:26:04 EST 2006
Frank,
On Thu, Feb 16, 2006 at 12:17:40AM -0500, Frank Warmerdam wrote:
> Markus,
> Good news!  I blew off all my paying clients for the evening and spent it
> digging through the NOAA 14 GCP problem.  It turns out to have been
> improper byte swapping code in the GCP reader.  It was applying 32bit byte
> swapping to 16 bit data values for pre NOAA 15 data.
> All fixed up in CVS now.
I am REALLY grateful to you, thanks for givig this such a
high priority. Maybe useful since I want to use the data
to support our stud of infectious diseases in Northern Italy
(EU EDEN Project).
I hope it didn't take too long to discover the problem (maybe
I shouldn't ask :-).
Right now:
 cvs [update aborted]: connect to cvs.maptools.org(209.217.116.153):2401 failed: Connection timed out
traceroute cvs.maptools.org
22  * * *
23  206.191.0.99 (206.191.0.99)  173.033 ms  180.389 ms  196.334 ms
24  access2.magma.ca (64.26.173.116)  190.849 ms  135.873 ms  143.317 ms
25  * * *
I'll try later again,
 Markus
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
