[Gdal-dev] download or buy BMNG dvd/cd ?
Lennox Antoine lxnyce at gmail.com
Tue Feb 21 12:13:19 EST 2006
I found this one a while back :
http://snowy.arsc.alaska.edu/
http://snowy.arsc.alaska.edu/nasa/
http://snowy.arsc.alaska.edu/nasa/bmng/
If you submit the info the earthobservatory though, eventually they
will send you direct download links as well.
-Lennox
On 2/21/06, Thom DeCarlo <t.r.decarlo at larc.nasa.gov> wrote:
> Matt,
> Did you get a response to this question? I noticed that at the bottom of the
> BlueMarble page (http://earthobservatory.nasa.gov/Newsroom/BlueMarble/)
> there are instructions for folks like us without BitTorrent access:
> Because of the very large file sizes, we are distributing the Blue Marble
> primarily through BitTorrent. If you are unable to use BitTorrent, please
> send email to: eo-bmng at eodomo.gsfc.nasa.gov to arrange an ftp download. Data
> is made available on a first come/first serve basis.
> Thom DeCarlo
>     Do Not Meddle in the Affairs of Dragons
> For You are Crunchy and Taste Good with Ketchup
> > -----Original Message-----
> > From: Matt Wilkie
> > Sent: Friday, February 17, 2006 6:07 PM
> > Cc: worldwind-dev at worldwindcentral.com; gdal-dev at lists.maptools.org
> > Subject: [Gdal-dev] download or buy BMNG dvd/cd ?
> > Hi Folks,   is there somewhere I can download or buy cdrom or dvd's for
> > the full Blue Marble Next Generation dataset?  (georeferenced?) Our
> > firewall disallows BitTorrent.
> > thanks,
> > matt wilkie
> > Geographic Information,
> > Information Management and Technology,
> > Yukon Department of Environment
> > 10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
> > 867-667-8133 Tel * 867-393-7003 Fax
> > http://environmentyukon.gov.yk.ca/geomatics/
> > Gdal-dev mailing list
> > Gdal-dev at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/gdal-dev
