[Gdal-dev] multipage geotiff
Bill Binko bill at binko.net
Wed Feb 22 15:35:27 EST 2006
Oh!  That would be:
    system("gdaladdo -r average abc.tif 2 4 8 16");
Just kidding!  Actually, I posted to mention that there is a bug in gdaladdo such that if you put enough summary levels in there that the "farthest out" overview is < 1 pixel, it will crash (at least on Linux).  So make sure you don't do something like the above on small test images.
Bill
Stephane Routelous wrote:
>Thanks,
>I would like to do it programmatically, so I will check the code of
>gdaladdo.
>Best Regards,
>Stephane Routelous
>-----Original Message-----
>From: Matt Wilkie [mailto:matt.wilkie at gov.yk.ca]
>Sent: Wednesday, February 22, 2006 3:24 PM
>To: Stephane Routelous
>Cc: gdal-dev at lists.maptools.org
>Subject: Re: [Gdal-dev] multipage geotiff
>>Hi,
>>I would like to generate geotiff images containing overviews
>>(basically sub-images with different resolutions) Can I do that ? If I
>>can, how ?
>yup:
>http://www.remotesensing.org/gdal/gdaladdo.html
>cheers :)
>matt wilkie
>Geographic Information,
>Information Management and Technology,
>Yukon Department of Environment
>10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
>867-667-8133 Tel * 867-393-7003 Fax
>http://environmentyukon.gov.yk.ca/geomatics/
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
