[Gdal-dev] problem building gdal in linux fedora core 1
Fernando González Cortés discoduro2 at terra.es
Mon Jan 2 11:31:46 EST 2006
I've done it! Well, I've read the link contents and understood it, but
the only thing I've gotten is to crash my postgresql server (now it
works again). Well, I've just copied the geos sources I downloaded at
the ogr/goes directory. After that I just executed "configure" without
arguments, "make" and "make install" without any problem.
Thank you for your help Ari.
Fernando
El lun, 02-01-2006 a las 12:49, Ari Jolma escribió:
> Fernando González Cortés wrote:
> > Hi Ari:
> > 	As you guessed, the geos library I have built is installed into
> > /usr/local/lib. I haven't that dir in /etc/ld.so.conf. But, ldconfig -v
> > reports a geos library. I Installed long ago postgresql-postgis-7.4.1
> > which needs geos-1.0. That version of geos is installed in /usr/lib and
> > this one is the one the ldconfig command reports.
> > 	I think it has to do with the problem, hasn't it? How can I tell the
> > compiler to access the geos I've just installed instead of the old one?
> for example
> http://www.tldp.org/HOWTO/Program-Library-HOWTO/shared-libraries.html
> gives some advice on how to do that, I don't have much experience with this
> Ari
