[Gdal-dev] gdal_translate Question
Matt Wilkie matt.wilkie at gov.yk.ca
Tue Jan 3 13:15:32 EST 2006
Paul Parisi wrote:
> Thanks for the help, Matt. It turns out the SRTM and Landsat files were
> using different coordinate systems. I found a converter online to go
> from lat/long to UTM, so I was able to use gdal_translate successfully.
> gdalwarp will do this too?
You can use cs2cs to translate lat/long coords into utm ones, to use for
  a gdal_translate crop. Then use gdalwarp on the output to convert the
  raster to a different projection. To get the two images cropped to
exactly the same extents it might be better to gdalwarp the source image
before cropping.
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
