[Gdal-dev] OCI-Import
Stephan Holl sholl at gmx.net
Wed Jan 4 10:46:30 EST 2006
Hello Frank,
thanks for your quick response.
On Wed, 4 Jan 2006 10:28:05 -0500 Frank Warmerdam <warmerdam at pobox.com>
wrote:
> On 1/4/06, Stephan Holl <sholl at gmx.net> wrote:
> > I was also told, that this results from the initial CREATE TABLE
> > statement, which was done by OGR, where the attribute-columns
> > were enclosed in quotes, something like this:
> > create table dataset (
> >      OGR_FID number(38),
> >      ORA_GEOMETRY MDSYS.SDO_GEOMETRY,
> >      "cat" number(38),
> >      "column" number(38),
> >   ..... ) storage (...) tablespace ... ;
> > For a select-statement the columns needs to be in quotes as well,
> > otherwise Oracle does not recognize the column-name correct.
> > Is this a bug or a feature? Does anybody can give me a hint how to
> > get arround this?
> Stepan,
> I suspect the problem is that lower case field names are
> being preserved by the quoting of the field name when they
> are created (in OGROCIWritableLayer::CreateField()s
> ALTER TABLE command.
> If this is the issue, then I think a reasonable solution would
> be to launder lower case names to upper, either all the time
> in CreateField(), or perhaps only when the layer creation option
> "LAUNDER" is set true.
> Are you building from source?  If so, I could try committing a
> change to do this, and you could test it.
I could build from source and have a quick test, if you let me know,
which sollution you prefered (LCO-option or all the time).
Best regards
	Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060104/55b76dda/signature.bin
