[Gdal-dev] error while loading shared libraries: libgdal.so.l
Wed Jan 4 21:06:33 EST 2006
On 1/4/06, ³Ãô <lumiousy at yahoo.com.cn> wrote:
> I installed the gdal in /usr/local.
> I added the /usr/local/lib to the  /etc/ld.so.conf file.
> But I can not use it in my programe demogdal.cpp.
> I have to compile it using -L/usr/local/lib -lgdal option.
> When I run the object file, the error came up as follows:
> error while loading shared libraries: libgdal.so.l: can not open shared
> object file:No such file or directory.
> But there is a libgdal.so.l in my /usr/local/lib.
> How can I make it?
I'm no guru on use of ld.so.conf, but don't you need
to run ld.config as root or something?   I normally
just add /usr/local/lib to my LD_LIBRARY_PATH.
Best regards,
