[Gdal-dev] ogr2ogr Point not Point ZM
Alex Mandel tech_dev at wildintellect.com
Thu Jan 5 13:42:25 EST 2006
When I do:
ogr2ogr -update -append two.shp one -nln two one -nlt POINT
The appended file, which has no points to begin with(but is basically
the same as the original with a couple of extra fields and the points
removed) ends up with geometry of type POINT ZM(3D). I need it to simply
be POINT(2D), no z or m values. ArcGIS software handles POINT and POINT
ZM very  differently so they are two distinctly different options.
I thought I had solved it by adding the -nlt POINT portion but it turns
out that didn't have any effect.
Whats really wierd is that I thought I had this working on a previous
data set.
Anyone know anything about this?
Alex
