[Gdal-dev] Datum shifting in GDAL utilities
Thu Jan 5 15:29:33 EST 2006
On 1/5/06, Antonin Orlik <antonin.orlik.hgf at vsb.cz> wrote:
> Dear developers,
> please, could anybody tell me why the ogr2ogr and gdal_warp are using
> proj utility for coordinates transformation instead of cs2cs utility?
> This fact makes quite a big  position error after the coordinate
> transformation between coordinate systems based on diferent ellipsoids
> (the proj utility cannot make datum shifting).
Antonin,
The ogr2ogr and gdalwarp programs use the pj_transform()
entry point in libproj.so (or PROJ.DLL) the same as cs2cs.
Could you be more specific why you think the programs
aren't doing datum shifting?
Best regards,
