[Gdal-dev] ecw
Fri Jan 6 17:25:03 EST 2006
On 1/6/06, ivan marchesini <marchesini at unipg.it> wrote:
> Hi list...
> I have tried to compile the gdal.1.3.1  against the ecwsdk.3.1
> downloaded from http://www.gdal.org/dl/
> I have a system with debian testing-unstable (a mix)
> I have already installed GrassGis against gdal (without ecw)
> and now I try to compile the gdal libraries with ecw support
> these are the steps:
Ivan,
I don't think GDAL supports the 3.1 SDK anymore.  I would
suggest downloading the current release candidate and installing
that for use with GDAL.
Best regards,
