[Gdal-dev] gdal_contour missing contours!
Jeshua Lacock jeshua at OpenOSX.com
Sat Jan 7 07:39:45 EST 2006
Hello,
This is almost certainly a user error, though I cannot figure it out.
I have a DEM (from NED imported to a new location with r.in.gdal -oe)
in GRASS that reports that the min/max Z values are:
   min = 958.760071 max = 2162.167236
But when I export it to a TIFF (with r.out.tiff) and use the command:
  	gdal_contour -a elev mydem.tif my-countours -i 10.0
It successfully creates a shape file with levels going in increments of
10 from 0 to 250. But there are many missing levels (below 0 and above
250), for example see:
	<http://OpenOSX.com/missing-contours.png>
A sample TIFF of the DEM is here:
	http://OpenOSX.com/mydem.tif
How would I get gdal_contour to use the same values for the cells that
GRASS uses (not 0-250, but the actual DEM elevation values)? Or short
of that, how would I get it to draw all of the contours?
Any help is greatly appreciated.
Thanks,
Jeshua Lacock ___________________________
Programmer/Owner		Phone:	877.240.1364
http://OpenOSX.com		Fax:		415.462.6211
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
