[Gdal-dev] gdal-grass install problems redux
Putler, Dan Dan.Putler at sauder.ubc.ca
Sat Jan 7 19:24:20 EST 2006
OK, so editing /etc/ld.so.conf to include the library and config
locations of proj, gdal, grass, and geos, and then running ldconfig
solves the problem. It took a while to find the appropriate email
thread from this list to set me straight. Frank, you might want to
mention the potential need to do this in the HELP file of gdal-grass
to prevent posts on this topic from the the lesser informed to this
list.
Dan
On 7-Jan-06, at 11:10 AM, Putler, Dan wrote:
> Hi,
> I am running into an identical install problem as Maik Trömel
> reported on 9 December. I'm running on an old P3 machine (so the
> potential problems with x64 aren't relevant in my case). In addition,
> I'm running FC4, while Maik (based on the configure output) is
> running SUSE. The particular relevant software versions I'm running
> are:
> proj 4.4.9
> gdal 1.3.1
> grass 6.0.1
> geos 2.2.1
> I built each of these from source. The one other piece of information
> that may be relevant is that grass was build with the --with-gdal
> option. The output of the configure is:
> [putler at ha667-1 gdal-grass-1.3.1]$ ./configure --with-gdal=/usr/local/
> bin/gdal-config --with-grass=/usr/local/grass-6.0.1
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking for ranlib... ranlib
> checking for g++ -shared ... yes
> user supplied gdal-config (/usr/local/bin/gdal-config)
> using /usr/local/lib/gdalplugins as GDAL shared library autoload
> directory
> checking for G_asprintf in -lgrass_gis... no
> configure: error: --with-grass=/usr/local/grass-6.0.1 requested, but
> libraries not found!
> Dan
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060107/56ba76cf/attachment.html
