[Gdal-dev] iODBC drivers for Mac OS X
Tue Jan 10 15:30:15 EST 2006
On 1/10/06, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Something like: either specify a .mdb directly like is is now, or as
> PGEO:dsn if one needs to use an alternate ODBC driver.  You could
> provide the full range of ODBC options, but I don't know if username
> is applicable, or geometry column, but password may be needed also
> (tho this Mac Access driver currently doesn't support password
> protected MDBs, others may).
William,
Ah, I had forgotten but the PGEO driver should still support
DSNs (as PGEO:dsn).
Best regards,
