[Gdal-dev] gdal-grass-ogr plugin 64bit issue
Otto Dassau dassau at gdf-hannover.de
Wed Jan 11 08:23:25 EST 2006
I have a problem compiling gdal-grass on my SuSE 9.2 64bit pc:
checking for ranlib... ranlib
/usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld:
conftest2.o: relocation R_X86_64_32 can not be used when making a shared
object; recompile with -fPIC
conftest2.o: could not read symbols: Bad value
collect2: ld returned 1 exit status
checking for g++ -shared ... no(1)
checking for ld -shared ... no
user supplied gdal-config (/usr/local/bin/gdal-config)
and found these mails in the GDAL ML.:
http://lists.maptools.org/pipermail/gdal-dev/2006-January/007577.html
http://lists.maptools.org/pipermail/gdal-dev/2006-January/007579.html
is this bug already fixed?
 thanks
   Otto
