[Gdal-dev] Error building for mac
Hopper, James E. JAMES.E.HOPPER at saic.com
Mon Jan 16 18:51:38 EST 2006
Think I got it.  I forgot some -D options.  Now I get
Test Script: gdalautotest_all
Succeeded: 401
Failed:    0 (0 blew exceptions)
Skipped:   192
When running tests same as the make file.
I am going to try to build an intel version for the new macs next.
Thanks jim
On 1/16/06 6:46 PM, "Howard Butler" <hobu at iastate.edu> wrote:
James,
*How* did you add a build target to xcode, by using the "External
Build Target," or by manually adding in files to an existing project.
I've found that I've had the most success with the "External Build
Target" layout in Xcode 2.2.  Do your normal configure process using
the terminal, and then pointing Xcode at the directory.  It even
picks up the CVS stuff if you're using that too.  I've found it to be
really nice.
BTW, deflate might be related to needing zlib to be internal as well.
Just a guess, I'm not sure though.
Howard
At 2:58 PM -0800 1/16/06, Hopper, James E. wrote:
>I added a target to my xcode project so that I could build a version of
gdal
>with jpeg/png/gif/tiff/geotiff would use internal versions.  When I run the
>autotests on it I get a lot of errors like the ones below.  Can anyone
point
>me at where I might have gone wrong?
>Thanks jim
>ERROR 1: IReadBlock failed at X offset 0, Y offset 0
>ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
>ERROR 1: data/rgbsmall.tif:Deflate compression support is not configured
>ERROR 1: TIFFReadEncodedStrip() failed.
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
<http://lists.maptools.org/mailman/listinfo/gdal-dev>
