[Gdal-dev] gdalwarp state plane?
Prasanth Chintamaneni prasanth at louisiana.edu
Wed Jan 18 15:17:05 EST 2006
I am trying to reproject my data using the below command,
gdalwarp -s_srs "EPSG:26982" -t_srs "+proj=latlong +datum=WGS84"
I am getting the following error
ERROR 6: EPSG PCS/GCS code 26982 not found in EPSG support files.  Is
this a valid
Help please?
Thank you,
Prasanth.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060118/6d3556aa/attachment.html
