[Gdal-dev] gdalwarp state plane?
Matthew Perry perrygeo at gmail.com
Wed Jan 18 20:30:49 EST 2006
Prasanth,
Try looking at your epsg file (/usr/share/proj/epsg  ?) to see if it
contains an entry for 26982 (it should).
Also try -srs "epsg:26982" or "+init=epsg:26982" and see if you get
different results. Some applications, and I'm not sure if gdalwarp is
one of them, are case-sensitive.
Matt Perry
On 1/18/06, Prasanth Chintamaneni <prasanth at louisiana.edu> wrote:
> I am trying to reproject my data using the below command,
> gdalwarp -s_srs "EPSG:26982" -t_srs "+proj=latlong +datum=WGS84"
> I am getting the following error
> ERROR 6: EPSG PCS/GCS code 26982 not found in EPSG support files.  Is this a
> valid
> Help please?
> Thank you,
> Prasanth.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Matt Perry
http://www.perrygeo.net
