[Gdal-dev] ECW support
Armin Burger armin.burger at gmx.net
Thu Jan 19 05:37:16 EST 2006
Tom, Angus,
I had the same problem when compiling the ECW SDK 3.3 RC 1 on Ubuntu 5.10
with GCC/G++ 4. The error never appeared on Debian 3.1 systems that use GCC
3.3. So I guess it could be related to the GCC/G++ compiler. But I hope this
problem will be fixed in newer releases.
Armin
> --- Ursprüngliche Nachricht ---
> Von: Tom Lynch <tflynch at gmail.com>
> An: "gdal-dev at lists.maptools.org" <gdal-dev at lists.maptools.org>
> Betreff: Re: [Gdal-dev] ECW support
> Datum: Thu, 19 Jan 2006 16:57:02 +0800
> G'day Angus,
> Haven't seen that one before, but if you investigate the offending
> line it does appear to be legal (and preceding lines etc.).  Although
> perhaps some more subtle parsing phenomenon is at work.  It appears to
> be interpreting CNCSJPCResample as a type rather than as the class
> that it is, so maybe you should consider forward declaring it in
> NCSJP2FileView.h.
> It's possible that the error is caused by order of compilation of
> files or something silly.
> Put a line class CNCSJPCResample; somewhere near the top of the header
> file and have another go.
> Failing that, can you quote me your gcc and Linux versions?
> For those who are wondering when the next ECW JPEG 2000 SDK cut will
> be available: we found some positively scary bugs in 3.3 RC1 which
> explains the delay.  Most of those are now fixed, so expect something
> fairly soon.  I won't give a precise ETA as they seem to jinx the
> whole process :-)
> Cheers,
> Tom Lynch
> Development, ER Mapper
> Phone:      +61 8 93882900
> Fax:        +61 8 93882901
> Email:      tom.lynch at ermapper.com
> Web:        http://www.ermapper.com
> Forums:     http://forum.ermapper.com
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Telefonieren Sie schon oder sparen Sie noch?
NEU: GMX Phone_Flat http://www.gmx.net/de/go/telefonie
