[Gdal-dev] Shape file header content
Fri Jan 20 09:27:20 EST 2006
On 1/20/06, sheba thomas <sheb_susan at yahoo.com> wrote:
>  i'm trying to import shape file to a .vec file map , but not getting the
> correct order .i'm not sure weather i'm getting all the values of Shape file
> header . so please any one can suggest  the header structure and order of
> the shape file header content.
Sheba,
I think you will need to provide more details.  What command
are you using?  What is a .vec file?  What makes you think the
order is wrong?
The ogr2ogr utility will convert features in the order they
appear in the shapefile with the possible exeption of when
you have an OGR supported spatial index (.qix) and you issue
a spatial query, in which case the shapes may be returned in
quadtree ordering.  Hmm, on second though, I think they are
returned "in order" even then.  I do a special pass ordering the
shapeids read from the quadtree.
Best regards,
