[Gdal-dev] EHdr: was ESRI flt nbits issue
Markus Neteler neteler at itc.it
Mon Jan 23 05:38:09 EST 2006
Cees,
On Mon, Jan 23, 2006 at 11:13:19AM +0100, Cees Wesseling wrote:
> Markus,
> The problem is that the EHdr driver is "misused" to read the .flt
> format. That ESRI format is generated from the ESRI GRIDFLOAT command.
> That command will not generate the nbits line.
thanks for telling me - I was about to complain to my
data provider!
> The ESRI white paper does not mentioned float data at all.
> At present the GDAL EHdr driver can read the flt format by recognizing
> some additional tags such as xllcorner, etc. in addition to ulxmap etc
> mentioned in the white paper.
> However the Create call of the EHdr driver will not create a format
> compatible with the ESRI FLOATGRID command.
> A new separate driver should be the best option to support the .flt
> format more robust. That can easily be programmed by cloning some of the
> EHdr code.
> But all confusion arises from the fact that some applications generate
> float data as ".bil" format while that is not supported in the white
> paper and some of these applications use "a different from the rest"
> approach to mixing the .flt and .bil format  for their purposes.
Thanks for the update!
 Markus
