[Gdal-dev] Help With Transparent Colors
Reinaldo Escada Chohfi rec at geodesign.com.br
Tue Jan 24 20:08:04 EST 2006
GeoExpress has both GUI and command line versions for batch
processing.  You can add 1000s of images to process using either version.
R.
At 10:15 PM 1/24/2006, Dolloff, Matthew D. (JSC-ER7) wrote:
>I’m not sure how well GeoExpress is an option because we are talking about
>thousands of files and GB of data.  I need to batch the process.
>From: Reinaldo Escada Chohfi [mailto:rec at geodesign.com.br]
>Sent: Tuesday, January 24, 2006 5:48 PM
>To: Frank Warmerdam; Dolloff, Matthew D. (JSC-ER7)
>Cc: gdal-dev at lists.maptools.org
>Subject: Re: [Gdal-dev] Help With Transparent Colors
>You can also use the GeoExpress 5.0 trial download from LizardTech (
>www.lizardtech.com) that allows you to mosaic and reproject .sid images in
>one step.  The trial download allows you to work with images that already
>are in .sid format without problems.  That way you don't need to go from
>MrSID to GeoTiff and make a large mosaic as a .sid image.
>Best regards,
>Reinaldo
>At 09:06 PM 1/24/2006, Frank Warmerdam wrote:
>On 1/24/06, Dolloff, Matthew D. (JSC-ER7) <matthew.d.dolloff at nasa.gov> wrote:
> > Hello.  I am trying to convert some MrSID images into Geotiffs and tiling
> > them together.  The MrSIDs are in state plane coordinate system and I need
> > them in WGS84.  So I convert the MrSIDs to geotiffs using mrsiddecode from
> > lizard tech.  Then I use gdal warp to change the projection type.  Then use
> > gdal_merge to merge them together.  The problem is that I end up with a
> > black collar when I warp the images and then when I merge them the images
> > cover each other up.  Is there anyway, that I can crop those collars out?
> > Here is the link where I am getting the sids
> http://www.nysgis.state.ny.us/gateway/mg/2001/suffolk/01ic_t_babylon_l06col.htm
>Matt,
>A couple of approaches would be:
>  o Use gdal_merge to merge the TIFFs before
>     reprojecting them.  Then gdalwarp the resulting
>     mosaic.
>  o Or create a big WGS84 mosaic file and gdalwarp
>     each non-WGS84 file into that, mosaicing at the
>     same time as reprojecting.
>In the future gdalwarp will support multiple input
>files, essentially replacing gdal_merge for many
>purposes.  This is already in CVS if you were building
>from source.  Another option would be to generate a
>nodata value or better yet an alpha channel in the files
>output by gdalwarp to keep track of the nodata pixels.
>My suggestion would be the top most option, mosaic
>then reproject.  Keep in mind that GeoTIFF only
>supports file sizes up to 4GB.  So if your mosaic is
>going to be large, you may need to do it in a format
>like Erdas Imagine.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
>Reinaldo Escada Chohfi, Ph.D.
>Diretor
>GeoDesign Internacional
>www.geodesign.com.br
>E-mail: rec at geodesign.com.br
>Tel./Fax: 0-XX-12-3153-5115 (Local)
>       55-12-3153-5115 (Intl.)
>Inteligência e Tecnologia Espacial de Ponta
>Urbanismo, Estudos Ambientais, Monitoriamento Ambiental,
>Geoprocessamento, GIS, Processamento de Imagens Geográficas,
>Sensoriamento Remoto: Imagens de Satélites
>Compressão de Imagens e Documentos Escanerizados
>Servidor de Conteúdo - Sistemas de Visualização - Integração de Sistemas
>Revendedor Autorizado da LizardTech e da Applied Imagery no Brasil
>Vila Peralta, 42
>12607-040 - Lorena - SP - Brasil
>Informação confidencial. Não retransmitir sem autorização.
>Copyright (c) 2005 GeoDesign Internacional
>Todos os direitos reservados.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060124/c058ad8e/attachment.html
