[Gdal-dev] ogr2ogr convert PostGIS-data to MapInfo TAB/ MIF-Files
Fischer, Andreas andreas.fischer at kreis-unna.de
Fri Jan 27 07:53:53 EST 2006
Hello,
a couple of weeks ago we had an issue about problems converting PostGis-data
to MapInfo TAB or MIF-files using ogr2ogr.
You will find the description of the problem under
http://bugzilla.maptools.org/show_bug.cgi?id=1198.
Can anyone let me know, if this problem is considered to be fixed?
I Would be glad to hear from you.
Thanks so far
Regards
Andreas Fischer
Kreis Unna
Dezernat III - Projektteam GIS
Platanenallee 16
59425 Unna
(02303) 27-2507
