[Gdal-dev] Problems with creating EHdr BIL
Fri Jan 27 14:15:38 EST 2006
On 1/19/06, Peng Gao <pgao at esri.com> wrote:
> We have run some tests on Ehdr, and found two small problems:
> - colormap is not persisted
> - NoData value is not persisted
Gao,
I have modified the EHDR driver to support saving color
tables as a .clr file, and saving nodata values in the .hdr
NODATA keyword.  I also added tests of this new
functionality to the EHDR test script.
Best regards,
