[Gdal-dev] ELAS
Sat Jan 28 23:04:13 EST 2006
On 1/28/06, Simpson <asimpson at i-55.com> wrote:
> Hello,
> I am running gdal 1.2.6.0 on Linux and would like to read ELAS files
> natively instead of dumping out to tif first.
> 'gdalinfo --formats' lists ELAS, but when executing 'gdalinfo
> some_elas_file.geo', I get 'not recognised as a supported file format'.
> Do I have to provide command line switch to tell it to use ELAS?
> The version of ELAS may be slightly newer than what the gdal ELAS code was
> developed for, but was told by developers the file structure hasn't changed.
Drew,
GDAL is supposed to auto-recognise file formats.  So
if gdalinfo doesn't recognise the format it is presumably
something different than the driver was written for.   Can
you point me to a sample file?
By the way, the ELAS test files I have all end with the
extension .odf.  I don't know if that is significant.
Best regards,
