[Gdal-dev] FIXED - OGR can't handle Null values in a Date field
Aaron Koning aaronkoning at gmail.com
Tue Jul 4 12:14:49 EDT 2006
Thanks a ton! This is uber-helpful.
Aaron
On 6/30/06, Mateusz Loskot <mateusz at loskot.net> wrote:
> Aaron Koning wrote:
> > Is there anyway of getting OGR to output Null values into a Date
> > field when there is a Null value present in the input Date field?
> Hi,
> Last days, I fixed this issue but due to my Internet connection was
> broken, I could not commit it.
> So, now I can and I've committed my changes to CVS.
> Changes:
> - Fixed Shape driver - NULL/0 date value was converted to string without
> zero fill for year, e.g. 0/00/00 instead of 0000/00/00.
> - Fixed NULL handling in PG driver - now, if date field stores year of
> 0000, the value is considered as NULL, because there is no ZERO year
> (this follows PostgreSQL/MySQL dates handling behaviour, interesting
> reference:
> http://groups.google.pl/group/mailing.database.pgsql-sql/browse_frm/thread/1685953a3ebf48c1
> So, I was able to import Aaron's shapefile to PostgreSQL 8.1.4.
> Here are my commands:
> ogr2ogr -f PostgreSQL PG:dbname=gdal_nulldate bugs/null_date/dates.shp
> NOTE: I renamed Aaron's shapefile to dates.shp
> Here is what I got in my gdal_nulldate database:
> gdal_nulldate=# \dt
>         List of relations
> Schema | Name  | Type  |  Owner
> public | dates | table | mloskot
> (1 row)
> gdal_nulldate=# \d dates
>                                   Table "public.dates"
>     Column    |     Type      |                        Modifiers
> ogc_fid      | integer       | not null default
> nextval('dates_ogc_fid_seq'::regclass)
> wkb_geometry | bytea         |
> dstrbedate   | date          |
> dstrbsdate   | date          |
> licenceid    | character(50) |
> permitid     | character(50) |
> blknmbr      | character(50) |
> Indexes:
>     "dates_pk" PRIMARY KEY, btree (ogc_fid)
> gdal_nulldate=# select dstrbedate, dstrbsdate from dates;
> dstrbedate | dstrbsdate
> 2001-02-07 | 2001-02-07
> 2001-02-08 | 2001-02-08
> 2002-02-01 | 2002-02-01
> 2002-01-05 | 2002-01-05
> 1999-01-06 | 1999-01-06
> 1997-12-24 | 1997-12-24
> 1999-03-03 | 1999-03-03
> 2001-11-01 | 2001-11-01
> 1998-12-21 | 1998-12-21
> 1998-09-10 | 1998-09-10
> 1998-02-04 | 1998-02-04
> 2001-01-08 | 2001-01-08
> 1996-12-23 | 1996-12-23
> 1992-11-13 | 1992-11-13
> 1996-01-05 | 1996-01-05
> 1990-01-01 | 1990-01-01
> (18 rows)
> gdal_nulldate=#
> NOTE: As you can see, two records store null dates, just as in the input
> shapefile.
> So, I assume this issue is fixed, but there are small things I'd like to
> explain/learn (regarding OGR Shape driver and dates).
> Please, see my comment marked with 'XXX - mloskot' in the
> ogr/ogrsf_frmts/shape/shape2ogr.cpp file.
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
|  Aaron Koning
|  Information Technologist
|  Prince George, BC, Canada.
|  http://datashare.gis.unbc.ca/fist/
|  http://datashare.gis.unbc.ca/gctp-js/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060704/761b0bf1/attachment.html
