[Gdal-dev] help with adding a projection definition
TC Haddad tchaddad at gmail.com
Thu Jul 6 13:46:09 EDT 2006
thanks bryan, that did the trick,
Tanya
On 7/5/06, Bryan Keith <bryan at geomega.com> wrote:
> Tanya,
> In my FWtools installation I find the epsg definitions in this file:
> <install directory>\FWTools1.0.0b2\proj_lib\epsg
> <install directory> for me is c:\programs\  By default, it's probably
> c:\program files\
> I also don't have 4495 in that file.
> Hope that helps.
> Bryan
> TC Haddad wrote:
> > I'd like to use gdalwarp to reproject some large geotiffs, but
> > apparently my projection of choice EPSG:4495 is not recognized by
> > gdal.
> > On a previous machine I had to edit an old version of proj4 to take
> > this EPSG code, and was successful at that time. The parameters were
> > as follows:
> > # NAD83 / Oregon Lambert (Intl ft)
> > <4495> +proj=lcc +lat_1=43 +lat_2=45.5 +lat_0=41.75 +lon_0=-120.5
> > +x_0=400000.00000 +y_0=0 +ellps=GRS80 +datum=NAD83 +to_meter=0.3048
> > no_defs <>
> > I'd like to do the same again, but I can't figure out where gdal is
> > getting it's projection definitions from... what file name should I be
> > looking for?
> > My situation is FWtools 1.0.0b2 installed on WinXP sp2
> > thanks for any help,
> > Tanya
> > Gdal-dev mailing list
> > Gdal-dev at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/gdal-dev
