[Gdal-dev] inconsistent "worldfile=on" options
Fri Jul 7 16:30:20 EDT 2006
Matt Wilkie wrote:
> Hi All,
> Is there a particular reason why gdal_translate support "-co
> worldfile=on" for jp2 jasper and jp2 mrsid but not jp2 ecw or kakadu?
> Or why png uses "-co worldfile=yes" instead of "on"?
> And the one I'm most curious about, why there isn't a global
> worldile=yes option for all formats?
Matt,
I'm afraid there isn't that much rhyme or reason to worldfile handling in
GDAL.  It is basically added on a driver by driver basis, and no always
consistently.   Most WORLDFILE parameter checks should be using
CSLFetchBoolean() which would honour ON, TRUE, 1, or YES as valid positive
values.  I checked, and it seems the PNG driver should honour them all.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
