[Gdal-dev] "collect2: ld returned 1 exit status" building ogrinfo
Mateusz Loskot mateusz at loskot.net
Mon Jul 10 03:23:37 EDT 2006
Mateusz Loskot wrote:
> I'll report it to strk as soon as I meet him.
> I suppose this problem can be solved with GEOS' ./configure switches
> to enable/disable inline expansion of functions.
> Maciej, could you try to build GDAL + GEOS on your box and see
> if you will get errors listed above about undefined references in libgeos_c?
> I'll try to fix/explain the libgeos_c issues very soon.
> I'm sorry for those problems and thanks for reporting them!
I posted a message about this issue to GEOS list.
Here it is in the archive:
http://geos.refractions.net/pipermail/geos-devel/2006-July/002432.html
Cheers
Mateusz Loskot
http://mateusz.loskot.net
