[Gdal-dev] proj4/wkt --> epsg
Mon Jul 10 09:20:40 EDT 2006
Mateusz Loskot wrote:
> Shoaib Burq wrote:
>> Hi, I was just wondering if there is a way to programatically convert
>> proj4 or wkt to and EPSG code in OSR?
> One of possibilities I see is to import SRS to OGRSpatialReference:
> char* pszWkt = "..."; // put here your SRS WKT definition
> OGRSpatialReference srs;
> srs.exportToWkt( &pszWkt );
> const char* pszTarget = 0;
> const char* pszAuthName = 0;
> const char* pszAuthCode = 0;
> if (srs.IsProjected())
>    pszTarget = "PROJCS";
> else
>    pszTarget = "GEOGCS";
> pszAuthName = srs.GetAuthorityName( pszTarget );
> if( NULL != pszAuthName )
>    if( EQUAL( pszAuthName, "EPSG" ) )
>       pszAuthCode = srs.GetAuthorityCode( pszTarget );
>       if( NULL != pszAuthCode )
>            // XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
>            // Here is the epsg code
>            int epsg = atoi(pszAuthCode);
> Similarly, you should be able to import SRS from PROJ.4 definition using
> OGRSpatialReference::importFromProj4().
> I've not compiled this code above, it is a copy&paste with small
> modifications from ogr/ogr2gmlgeometry.cpp file, starting from line 235
> where I retrieve EPSG code to save it as a value of srsName - GML
> attribute.
Mateusz / Shoaib,
The above will work if there is an ESPG authority code in the WKT.
Unfortunately, if you import a definition from PROJ.4 there is no
indication of the epsg code, so there will be no epsg authority codes
in the WKT representation.
Generally speaking there is no good way to go from PROJ.4 to EPSG codes.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
