[Gdal-dev] proj4/wkt --> epsg
Shoaib Burq hydromap at gmail.com
Mon Jul 10 23:06:09 EDT 2006
Thanks Mateusz/Frank that explains a lot.
I used gdalwarp to reproject a dataset using proj4 directives. When
looking at its WKT it appears very scant and doesn't contain AUTHORITY
attribute.
This might be a dumb question but do you know if WCS specification and
its Mapserver implementation only allow EPSG codes for the
GetCoverage() request and not Proj4?
thanks heaps
shoaib
> The above will work if there is an ESPG authority code in the WKT.
> Unfortunately, if you import a definition from PROJ.4 there is no
> indication of the epsg code, so there will be no epsg authority codes
> in the WKT representation.
> Generally speaking there is no good way to go from PROJ.4 to EPSG codes.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGF, http://osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
