[Gdal-dev] Re: Problem with HDF4 samples
Daniele Romagnoli dany.geotools at gmail.com
Thu Jul 13 06:20:19 EDT 2006
Ok...
Stupid question :)
Now I'm downloading the HDF4 library.
I'm sorry...
On 7/13/06, Daniele Romagnoli <dany.geotools at gmail.com> wrote:
> Hi list,
> I'm trying to exploit the HDF4 files provided in the GDAL samples download
> area:
> http://dl.maptools.org/dl/gdal/data/hdf4 or
> ftp://ftp.remotesensing.org/gdal/data/hdf4
> However, when trying to open them (as an instance, by using gdalinfo in
> order to check available datasets), I get this error:
> ERROR 4:
> `d:\DatiPlugin\MO36MW14.chlor_MODIS.ADD2001089.004.2002186190207.hdf'
> not recognised as a supported file format.
> Someone can help me?
> If the 2 files aren't valid samples, where I can find some working HDF4
> sample to use with GDAL?
> Thx a lot.
> Best Regards,
> Daniele
Best Regards,
Daniele
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060713/cc4750c1/attachment.html
