[Gdal-dev] need tools for TIF image reprojection
Andrew Williams awilliams at rapidmap.com.au
Thu Jul 13 19:24:44 EDT 2006
zhonghai,
I've litterally translated hundereds of TIF's from all over the world from multiple projections to multiple projections. I have also had "failures". However, in every case, it was either my fault in specifying the -s_srs or -t_srs. In some cases the fault lay in the original image. The TIFF itself was supplied with incorrect georefernceing information and so it was never going to work.
Have you got a dump from GDALINFO that we can see and the GDALwarp command line you've used?
regards
Andrew
	-----Original Message-----
	From: Zhonghai Wang [mailto:zhonghaiw at gmail.com]
	Sent: Fri 7/14/2006 12:14 AM
	To: gdal-dev at lists.maptools.org
	Cc:
	Subject: [Gdal-dev] need tools for TIF image reprojection
	Hi guys,
	I need a tool to reproject my TIF images, either free or non-free software.
	I've tried with the GDAL utilities, sure I can do the reprojection, but the coordinates seems not correct, there are serveral hundert meters displacement according to the my base maps.
	thanks for your info.
	zhonghai
