[Gdal-dev] Extracting HDF metadata
Inessa Shalomov ishalomo at yahoo.com
Fri Jul 14 23:21:32 EDT 2006
Has anyone tried to extract specific metadata fields from an HDF file format with GDAL?
  I am trying to use GDAL and its HDF file format support to extract specific metadata fields from an HDF file. The GetMetadataItem() call is not recognizing the metadata keys I am passing in, although according to the spec I am using, the keys are valid.
  I used the following code to
  GDALDataset *poDataset;
  GDALAllRegister();
  poDataset = (GDALDataset *) GDALOpen (pszFilename, GA_ReadOnly);
  const char* retval = poDataset->GetMetadataItem(“PRODUCT_UL_CORNER_LAT”, NULL);
  Am I not making the right API calls for HDF? Are there any additional method calls to retrieving the metadata?
  Any help would be greatly appreciated.
Thanks
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060714/1a4a8767/attachment.html
