[Gdal-dev] Black border (null value) after changing projection: possible to remove this?
wqual wolfgang.qual at gmx.net
Wed Jul 19 03:27:09 EDT 2006
Hi gdal-list,
Recently, I had to change the projection of some satellite tiles. I used
gdalwarp for this purpose and it worked perfectly.
The only thing is: as the tiles were rotated a little bit, black triangles
(representing null-values) appear because of the rotation).
When I load these tiles in one view or a mapserver map, these black triangles
overlay adjacent tiles a little bit.
Therefore my question:
Is there a possiblity to remove these "triangles" resp.: can I define them as
transparent? I would like to put them into a mapserver map using gdaltindex.
I would be grateful for some comments about this.
Best regards,
Wolfgang
