[Gdal-dev] using gdaladdo with tiled tifs
Jeff Hoffmann jeff at propertykey.com
Wed Jul 19 14:39:16 EDT 2006
I have a question about the best way to create overviews in tiled tifs.
    I've created my tifs with a block size of 512x512 with the
understanding that this should help with performance if I'm pulling
small blocks (say 500 x 500 pixels) from much larger images (say 20k x
20k pixels).  So when I created that tif, I passed a bunch of command
line configuration options to gdal_translate to get the tiling I
selected, but when I did overviews, I just did a plain "gdaladdo my.tif
2 4 8 16 32" without any options.  Should I be telling gdaladdo all of
the same tiling options as when I created the tif?  Or does it just know
to use the same configuration as when it was created?  Or doesn't it
matter?  Also, I've chosen to compress the original tif because most of
the usage will come from the overviews.  Do I need to tell it not to
compress the overviews or is that the default and I actually have to
tell it to compress the overviews?
Jeff Hoffmann
Head Plate Spinner
PropertyKey.com
