[Gdal-dev] cutting an image
trale at centrum.cz trale at centrum.cz
Fri Jul 21 14:07:15 EDT 2006
Frank,
if I gdal_translate with TILED=YES and then use splittiff from the FWTools, will that results in individual tiif tiles?
______________________________________________________________
> Od: warmerdam at pobox.com
> Komu: trale at centrum.cz
> CC: gdal-dev <gdal-dev at lists.maptools.org>
> Datum: 21.07.2006 19:37
> Předmět: Re: [Gdal-dev] cutting an image
>trale at centrum.cz wrote:
 >> Hi list,
 >> is there some tool tocut an geotiff image into tiles ?
 >Nick,
 >I'm not aware of one that does it all for you.  You can use gdal_translate
 >to cut out a tile from a bigger image, but to auto-tile an image you
 >would need to write a script around that.
 >I think example programs for this may have been submitted previously on
 >this (or perhaps the mapserver-users) list so you might want to do some
 >searching.
 >Best regards,
 >I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
 >light and sound - activate the windows | http://pobox.com/~warmerdam
 >and watch the world go round - Rush    | President OSGF, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060721/cd2c5fd9/attachment.html
