[Gdal-dev] cutting an image
trale at centrum.cz trale at centrum.cz
Sat Jul 22 09:47:30 EDT 2006
Hi Frank,
I ended up with modifying the gdal_translate to autotile the image. The API is more user friendly then I expected.
Thanks,
regards,
Nick
______________________________________________________________
> Od: warmerdam at pobox.com
> Komu: trale at centrum.cz
> CC: gdal-dev at lists.maptools.org
> Datum: 21.07.2006 21:03
> Předmět: Re: [Gdal-dev] cutting an image
>trale at centrum.cz wrote:
 >> Frank,
 >> if I gdal_translate with TILED=YES and then use splittiff from the
 >> FWTools, will that results in individual tiif tiles?
 >No, I'm afraid not.  I assume you mean tiffsplit, but it just splits
 >separate "pages" into individual files.  It doesn't split based on tile
 >or strip boundaries in the TIFF file.
 >Best regards,
 >I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
 >light and sound - activate the windows | http://pobox.com/~warmerdam
 >and watch the world go round - Rush    | President OSGF, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060722/35dd5b43/attachment.html
