[Gdal-dev] Bug in osr.py CoordinateTransformation for mercator projection?
Christopher Barker Chris.Barker at noaa.gov
Mon Jul 24 16:12:54 EDT 2006
Hi all,
I'm struggling with trying to figure out how to convert pixels to
lat/long for a raster nautical chart in BSB format.
Part of why I'm having trouble is that there is either a bug in
osr.CoordinateTransformation, or i am missing something important in how
it's supposed to work.
I'm trying to set up a Mercator projection with:
osr.SpatialReference.SetMercator, like so:
proj = osr.SpatialReference()
proj.SetWellKnownGeogCS( "WGS84" )
proj.SetMercator(clat = 0,
                  clong= 0,
                  scale=1,
                  fe=30,
                  fn=30,
While I'm not sure what all the parameters should be from the BSB file,
I do have some idea. Most of the parameters behave as I suspect, except
that the "scale" parameter seems to do nothing. It's kind of critical
for my needs, however. Despite the value of the scale parameter not
effecting the results, if I pass in a zero, I get an error (which I
would expect), so it looks like the value is being passed to Proj4. What
am I missing?
I've enclosed a little test script that does a transformation with
different scale values, and there is no difference in the output.
Or do I need to do the scaling my self?
By the way, is there a better list to ask this on? this is the third
related question I've asked, with nary a reply -- maybe I'm on teh wrong
list.
-thanks,
-Chris
Christopher Barker, Ph.D.
Oceanographer
NOAA/OR&R/HAZMAT         (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
Type: text/x-python
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060724/d48d1817/MercatorTest.py
