[Gdal-dev] GML to shapefile
Mateusz Loskot mateusz at loskot.net
Wed Jul 26 04:37:02 EDT 2006
Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> a while ago I reported a problem with Mapserver GML to shapefile
> conversion using ogr2ogr, the dbf column names are ms:XXXX.
> Has this been fixed (ie the namespace removed from the attribute name)?
> Should I open up a bug report?
Hi Bart,
Obviously, I've forgot about this problem, I'm sorry.
So, please, file a bug with sample GML files attached then it won't be
forgotten.
AFAIR from our e-mails exchange you were going to file a bug with
sample data files:
http://lists.maptools.org/pipermail/gdal-dev/2006-May/008944.html
and here is your last response I got about this problem:
> Hi Mateusz,
> I have the file at work, will open up a bug on Monday and attach it to it.
> Best regards,
> Bart
>>> Hi Frank, Mateusz,
>>> I am not saying it is invalid GML, I am saying the values are wrong.
>>> XMIN and YMIN in the Mapserver GML are:
>>> 192519.015625
>>> 320687.375000
>>> But in OGR's output they are both 0.
>>> I will file some bugs on Monday.
>> Hi,
>> Strange.
>> I have a sample of GML 2.0 file with
>> <gml:boundedBy>
>> <gml:Box>
>> <gml:coordinates>
>> 278653.100,187444.800 279095.300,187898.250
>> </gml:coordinates>
>> </gml:Box>
>> </gml:boundedBy>
>> and after I run
>> ogr2ogr -f "GML" test.gml MySampleGML.gml
>> the output is changed but correct:
>> <gml:boundedBy>
>> <gml:Box>
>> <gml:coord><gml:X>278653.1</gml:X><gml:Y>187444.8</gml:Y></gml:coord>
>> <gml:coord><gml:X>279095.3</gml:X><gml:Y>187898.25</gml:Y></gml:coord>
>> </gml:Box>
>> </gml:boundedBy>
>> I'd need to test using your GML file. Is it possible send me one?
>> Cheers
Mateusz Loskot
http://mateusz.loskot.net
