[Gdal-dev] "gdalinfo --formats" output
Mateusz Loskot mateusz at loskot.net
Wed Jul 26 11:33:33 EDT 2006
Frank Warmerdam wrote:
> Mateusz Loskot wrote:
>> Daniele Romagnoli wrote:
>>> Hi list,
>>> when using the command "gdalinfo --formats"
>>> it returns a sequence of supported formats, as well as the specific
>>> driver capabilities which are symbolized by some initials: (ro), (rw)
>>> and (rw+).
>>> I think that (ro) means readonly while (rw) means read-write
>>> capabilities
>>> If I'm right, what is the difference between (rw) and (rw+)?
>>> The difference is related to Create and CreateCopy methods?
>> Yes, that's the difference.
>> ro - read-only dataset support
>> rw - create support (Create)
>> rw+ - create copy support (CreateCopy)
> Daniele / Mateusz,
> A slight variation on this.
> ro is read-only
> rw is read or write (ie. supports CreateCopy)
> rw+ is read, write and update (ie. supports Create)
Daniele,
I'm sorry, my fault, I misinform you about rw and rw+.
My explanations should be inversed: rw -> CreateCopy and rw+ -> Create.
Frank is right.
Frank,
Thank you for correction.
Best regards
Mateusz Loskot
http://mateusz.loskot.net
