[Gdal-dev] building gdal with kakadu
trale at centrum.cz trale at centrum.cz
Thu Jul 27 03:14:20 EDT 2006
Hi Frank,
the warping issue is happening with the FW Tools. I can post the image somewhere if you would like to have a look. Both datums are WGS84. This is kind of critical for the application I am working on. Any help is highly welcome ...
Thanks a lot
Nick
______________________________________________________________
> Od: warmerdam at pobox.com
> Komu: trale at centrum.cz
> CC: gdal-dev at lists.maptools.org
> Datum: 27.07.2006 00:42
> Předmět: Re: [Gdal-dev] building gdal with kakadu
>trale at centrum.cz wrote:
 >> Hi Frank,
 >> I figure that out somehow. I have kakadu 4_2_1_00336C with gdal13
 >> working now.
 >Nick,
 >Well referring to GDAL 1.3 is a bit non-specific since it encompasses
 >3 releaes (1.3.0 through 1.3.2) over roughly a year.  In any event,
 >I guess it doesn't matter since you got past that.
 > > There is other issue that worried me more. I have this
 >> output on gdalwarp.- it used to work. Any idea or workaround ? here is
 >> the dump:
 >> C:\ ...... >gdalwarp -t_srs WGS84 mosaic.tif geomosiac.tif
 >> ERROR 1: Too many points (441 out of 441). failed to transform, unable
 >> to compute output bounds
 >> mosaic.tif is in UTM and it is ok, based on globalmapper
 >Likely issues include:
 >   o PROJ.4 DLL not being found, so no reprojection works.
 >   o Different and incompatible datums.
 >   o Or perhaps missing datum shift files.
 >It would be helpful to have the gdalinfo report on the input file.
 >In fact, if the gdalinfo report file does not report lat/long bounds
 >as well, that means there is something fundamental broken with regard
 >to projections.   In that case, one option might be to use FWTools for
 >the warping since all the projection related stuff is properly setup
 >with it.
 >Best regards,
 >I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
 >light and sound - activate the windows | http://pobox.com/~warmerdam
 >and watch the world go round - Rush    | President OSGF, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060727/258ef7d7/attachment.html
