[Gdal-dev] Little experiment: comparison of vector projection OGR and ArcGIS
Dylan Beaudette dylan.beaudette at gmail.com
Sat Jul 29 22:14:45 EDT 2006
A while back I was wondering if ArcGIS and OGR would produce the same
output from the same projection operation...  Results where identical
for operations within the same datum, using a GCS -> UTM projection.
A couple days ago I did another experiment, this time incorporating a
datum shift: GCS NAD83 --> UTM NAD27. I have summarized the results
here:
http://casoilresource.lawr.ucdavis.edu/drupal/node/259
of note:
- the default tranform in ArcGIS does not produce the correct results.
- the 'NADCON' transform in ArcGIS produces the same results as OGR.
Any comments on some of the questions posed are welcomed.
Cheers,
Dylan
