[Gdal-dev] converting lines to polygones with ogr
Mon Jul 31 09:28:56 EDT 2006
C.Strobl at dlr.de wrote:
> hi all,
> is there a possibility to convert with ogr lines to polygones, for example like
> ogr2ogr -f  "ESRI Shapefile" -nlt POLYGON c:\home\dat_poly.shp c:\home\dat_line.shp
> or does somebody know another open source solution for this task.
> thanks for your help and greetings from munich
> christian
Christian,
There is no direct way to convert lines to polygons with ogr2ogr.
However, there is a demonstration python script for doing this at:
   http://www.gdal.org/srctree/pymod/samples/assemblepoly.py
This particular example assumes polygons are being built from a bunch
of edges.  In your case you are presumably building them from a single
linestring.  So basically you would only want to pass one linestring in
the argument to BuildPolygonsFromEdges.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
