[Gdal-dev] issue warning to user when performing datum shift (OGR, GDAL)
Mon Jul 31 16:58:53 EDT 2006
Dylan Beaudette wrote:
> Hi everyone,
> In light of some recent thought, experimentation, and discussion [1] I
> am wondering if it would be at all possible or even desirable to warn
> the user when a datum shift operation is about to be performed. Within
> the US, and assumming that the NADCON grid was installed with Proj4,
> transforming between NAD27 and NAD83 should work just as expected.
> However, in other parts of the world, this may not be the case.
> Therefore, it might be a good idea to follow the model used in GRASS,
> where the user is specifically prompted for datum transform parameters
> whenever defining a new locatio, in these situations.
> Any thoughts / reasons not to do this?
Dylan,
Well, the most obvious reason not to do it is that the GDAL utilities
are not interactive.  So there is no opportunity to ask.
I think it would be very nice if there was a mechanism to ask stuff
like ogr2ogr to describe what it will do in a transformation but even doing
that would be pretty challenging.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
