[Gdal-dev] projection info in mapinfo tab files corrupt whenspecifying -a_srs or -s_srs and -t_srs in ogr2ogr
Richard Matsunaga richard.matsunaga at waypointinfo.com
Thu Jun 1 12:01:48 EDT 2006
Now I'm confused. I had to fix this in order to get OGR working MI tabs.
Once the new release came out, I started using that version and it still
worked, so I assumed that the flag was changed in the GDAL build. Am I
wrong? Maybe I have some unintentional referencing happening!
The issue Peter has described is exactly the one which I was experiencing
and was solved by Daniel's suggestion below.
Richard
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank Warmerdam
Sent: May 31, 2006 11:08 PM
To: Daniel Morissette
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] projection info in mapinfo tab files corrupt
Daniel Morissette wrote:
> This may be related to a bug in the MITAB library which is used by OGR
> to read/write TAB files:
> http://bugzilla.maptools.org/show_bug.cgi?id=1319#c7
> See also:
> http://bugzilla.maptools.org/show_bug.cgi?id=1254
> Perhaps try rebuilding gdal/ogr/ogrsf_frmts/mitab with
> -DMITAB_AFFINE_PARAMS (and then relink ogr2ogr) and see if the crash
> goes away.
Daniel,
Should I be changing GDAL to build mitab this way?  Is there a reason this
isn't the default?
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGF, http://osgeo.org
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
